supercharger fuel question?
Old 02-01-2005 | 05:37 PM
JoeBallz's Avatar
JoeBallz
Default supercharger fuel question?
i just got my hands on a jackson racing supercharger cheap. my car is mostly stock except for header, intake, exhaust. what other upgrades will i need to do so i dont destroy my motor. i know i need more fuel. should i do injectors, fuel regulator and fuel pump or just 1 of these? thanks.
Old 02-01-2005 | 06:02 PM
dubcac's Avatar
dubcac
I
I believe the JRSC kit comes with a boost dependant fuel pressure regulator. What I would do is get some larger injectors and a hondata s200 so the car can be better tuned...I'd also get the Hondata intake manifold gasket. You could get an adjustable fuel pressure regulator to set your baseline pressure too...the stock fuel pump should be fine with hondata/injectors, because the pressure won't be super high and fry the pump. Spend some time on the dyno with a guy that knows what he's doing, and you'll make more power and be safer.
Old 02-01-2005 | 08:15 PM
JoeBallz's Avatar
JoeBallz
hey thanks for the advice. i went on the hondata website. its a little confusing. you recommended the s200. i saw that but it looks as though you have to ad options to it such as boost, datalogging etc. how much is a S200 with the options i need, if you know? also which options do i need? thankz.
Old 02-01-2005 | 08:49 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It will cost a decent chunk of change with the actual chipping, OBD conversion harness (if applicable), and tuning. I would step up the injectors as well since the stock ones will most likely be overloaded.
