spoon n1 question
Old 01-28-2005 | 09:05 PM
fgfournet's Avatar
fgfournet
R ENVY
Default spoon n1 question
I have a spoon n1 axel back and the flange on the silencer looks like its only goin to fit on the oem mid section. I have an after market mid section also, but the flange is flat unlike the oem. Has any one set up there exhaust to work with these two flanges? I don't want to cut the spoon axel back. Is there a flange that I could get welded to the mid section?
Old 01-29-2005 | 03:46 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
i thought the spoon n1 was a bolt on part
or so the site stated
it should bolt right on
Old 01-30-2005 | 08:00 AM
Dave-ROR's Avatar
Dave-ROR
RAD owns.
It's a bolt on for a stock B-pipe or an aftermarket B-pipe with the stock flange.
You should be able to get a new flange that will work welded on at a muffler/exhaust shop I would guess.
Old 01-30-2005 | 10:22 PM
fgfournet's Avatar
fgfournet
R ENVY
It is a direct bolt on. It's on my stock B-pipe know. I just wanted to use the after market exhaust because it doesn't have the bottle necking. Thanks for the info, I'll see what I can come up with.
Old 01-30-2005 | 11:23 PM
madtownhonda's Avatar
madtownhonda
It will work fine with the flat style flange. You just need to find a flat style gasket to go with it. I use a thermal r&d b-pipe with my spoon n1 rear section.
Old 01-31-2005 | 12:27 PM
pUrExTc's Avatar
pUrExTc
殺生丸
how does it sound?
Old 01-31-2005 | 10:55 PM
madtownhonda
Originally Posted by pUrExTc
how does it sound?
really loud
here's a short clip to get an idea
http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
Old 03-16-2005 | 08:36 PM
The Question's Avatar
The Question
Default Spoon b-pipe/axle-back
What about the Spoon B-pipe, it will directly bolt right on with the spoon n1 rear section, right. But will the spoon mid section (b-pipe) bolt directly right on to the stock cat??
Old 03-17-2005 | 11:36 AM
RisforTypeR's Avatar
RisforTypeR
Looks like it would bolt onto the cat:
Old 03-17-2005 | 12:35 PM
The Question
How is the quality and design, are they also both (N1 axle-back and b-pipe) stainless, or stainless steel?
