Antenna....
Old 01-16-2005 | 08:29 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
My worm gear broke too, and I swapped in a Fuba. Pain in the ass to get the old one out. Well if you don't want to 'remove all your paneling to expose the antenna hideout. I just bent mine back, but I had to fight it off as it wanted to come back at me since I just moved it instead of removing it.
Old 12-11-2005 | 11:39 AM
psg-1's Avatar
psg-1
Thanks for this old post Dave. I ran into an identical problem (plus some winter ice) and a simple search revealed this post at the top.
Further testimony to the power of the seach button.
Old 12-11-2005 | 01:12 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
You're quite welcome. :cheers: Thanks for searching.
With a couple gazillion archived threads, the power of that button is nearly limitless.
Old 12-12-2005 | 04:14 AM
csprague's Avatar
csprague
Warthog Pointyhead
You can also pick up a switch at Home Depot and wire it inline with the antenna. That's what I did because I got sick of hearing the thing go up and down everytime I turned my head unit on/off. Now on the rare occasion that I want to listen to the radio, I flip the switch up and the antenna comes up, but otherwise it stays down. Saves wear and tear as well.
Old 12-12-2005 | 08:39 AM
torn_phoenix's Avatar
torn_phoenix
you would
I did the same thing as csparaque. It was a lot easier then taking off the rear panels. Took about 35 minutes tops.
Old 12-12-2005 | 08:43 AM
bnuk's Avatar
bnuk
I put a short DIY in this thread on wiring a switch in to control the antenna.
https://www.honda-acura.net/forums/s...d.php?t=215007
Old 12-12-2005 | 07:16 PM
98 integra's Avatar
98 integra
gsr chick u said that your friend bought a new antenna motor..... do you remember how much it was??? cuz mine is shot and i heard they arnt cheap.... thanks
