Hydrolocked...!!!!!
Hydrolocked...!!!!!
damn!!! thrash my motor....didnt see a fat puddle on the street and didnt have time to turn for the puddles...tried taking out the spark plugs and cranking it didnt work...I charge up my batteries from my friend car....work but the i hear somthing cranking....towed it to my house now im doing a quick rebuild....
Originally Posted by Chizzy
what is hydrolocking? when water splashes into your cold air intake?
So when the piston is coming up on the compression stroke, the water will be forced up into the top of the combustion chamber, causing the engine to stumble (at the very least) or stall outright.
If the pistons, conrods and cranks are all robust and the amount of water is very slight, you might luck out and only have to replace the head gasket and get a new set of spark plugs. but more often than not, significant engine damage is the result. Snapped conrods, shattered piston rings, or even structural failure of the piston itself.
So if you choose to run a CAI, IMO it's foolish to not use a bypass valve as well. The best plan of all is to fabricate ducting to supply a short-ram intake with a supply of cold air -- without sealing the intake tract off.
When I first got my car it was completely stock,
I hit a huge puddle and the dang thing stalled
i waited about 15 minutes started it back up
and i was on my way, been working fine ever since.
thats not hydrolock right?
cause I had all stock intake etc. at the time..
what is that?
water in the altinator??
please shed some light on what happend to me
thanks
what is that?
thanks
