Jackson Racing Supercharger for LS/VTEC?
Old 12-12-2004 | 02:03 AM
WojtekG's Avatar
WojtekG
Originally Posted by Master Yodub
Are you running a stock bottom end?
I've got stock bottom but with block girdle installed and Type-R bolts fitting head to block.
Old 12-12-2004 | 02:05 AM
WojtekG's Avatar
WojtekG
Originally Posted by Kai
You need one for the PR3 (B16A/B, B18C5) head thanks to it's different bolt pattern. It should mount as if you where bolting it to a B18C5 considering the deck height and head casting.
Do you think there is difference between kit for Civic SI and GSR kit in this respect. I've tried to contact Moss Motors directly, but for some reason I haven't received any answer from them Yet. I will try again.
Old 12-12-2004 | 07:56 AM
newgsrdriver's Avatar
newgsrdriver
Yes there is a difference. You would have to redrill the manifold. You must use the B16/B18C5 kit, NOT the GSR kit.
Old 12-12-2004 | 10:12 AM
WojtekG's Avatar
WojtekG
So I have problem. High Boost JR kit includes Hondata ECU, so if I select Type-R kit I will get Ecu for OBD-2. I need Ecu for '94 teg, so that's why I thought taht '94 GSR kit would fit.
Anyway, I thought that if I install JR Supercharger, than intake manifold will be replaced anyway with the charger's manifold, isn't it? B18C1 and B18C5 should have the same intake manifolds fittings, am I right?
Old 12-12-2004 | 12:41 PM
Snoopy's Avatar
Snoopy
been there done that
the actual bolt patterns are different between b18c1 and b16/b18c5 heads
