Huge Oil Burning Problem
Old 12-05-2004 | 06:34 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I am using 10w30 at the moment. It does smoke a bit more when cold but it also smokes a lot when warm too. I drove around today and didn't notice much, if any, oil burnoff on my bumper. That is probably because it was raining. I am just trying to be optimistic about this because I don't want to replace the seals and I am hoping this $5 fix was the problem.
But what I don't understand is why it is burning so much more oil after I removed the head than it did before.
Old 12-23-2004 | 03:55 PM
99GSRbeerman's Avatar
99GSRbeerman
There is a speed limit?
my 99 gsr is doing the same thing...i switched my pcv and checked the compression.....and also checked the plugs. my teg isnt burning as much oil but its enough to cover the bumper. i have about 85k miles on mine.....cant figure it out either
Old 12-23-2004 | 07:11 PM
95tegRS's Avatar
95tegRS
Originally Posted by Master Yodub
Black smoke = rich
Burning oil = bluish/white smoke
If your blowing bluish white, means your buring oil, If your blowing black, then your running rich. (just like quoted above
Old 12-23-2004 | 08:24 PM
carta79's Avatar
carta79
Life after death
Originally Posted by Shmoo
I have the greddy kit and I only have the blue box for engine management right now. I don't really know what I should do about the engine management.
Like Master Yodub already stated a leakdown test would yield more info, I agree with him. Maybe you should consider upgrading the EMS, just a thought. It's a pretty well known fact that the "Blue box" runs rich, it's preconfigured that way.
The greddy blue box coupled with occasional trips to Vtec under boost on a high mileage motor. That would equal quite a bit of oil consumption IMO.
Keep us updated!
Old 12-23-2004 | 10:18 PM
Provocateur
On permanent hiatus
Keep us updated!
I am still having the problem but I have determined that it is happening most frequently when I am cruising at around 70 on the freeway and I punch it to pass someone. I can see whitish smoke behind the car. I don't know why it only does it then because in lower gears under full boost I can't see smoke behind me. I am thinking about a catch can if that will work because I am venting the breather hose into the intake tract before the compressor. So, maybe the compressor is burning the vapors and sending the smoke straight into the engine. This could all be a shot in the dark but I will try anything to get rid of this problem that has been plaguing me ever since I got my car 2 years ago.
I am also planning on upgrading from the Greddy blue box because I know it is making me run super rich. I don't want to get my ECU chipped with the Hondata because of cost and smog regulations in CA (even though that is my best option), so I was thinking of going with the tunable Greddy E-Manage. I haven't heard much about it but it is cheap and tunable, so if it sucks, I will sell it and think about Hondata.
I think valve stem seals are fine because I am not burning oil under vacuum or under cold conditions like mentioned previously. They can't be ruled out until a leakdown test is done, so I will leave that open.
Are there any other ways that I could be burning this much oil with those compression numbers, seemingly fine valve seals, and a new PCV valve?
Old 12-24-2004 | 01:12 PM
j87w's Avatar
j87w
What kind of condition is the turbo in? In my buddys 300Z the turbo seal had gone out and it was burning oil through the turbo. Just an idea.
Old 12-25-2004 | 02:44 PM
Provocateur
On permanent hiatus
The turbo is practically brand new. It has been on for around 1500 miles. I will check it out though.
Old 12-25-2004 | 10:58 PM
dubcac's Avatar
dubcac
I
I would run a catch can with turbo.
Old 12-26-2004 | 09:48 AM
ls_101's Avatar
ls_101
integra fs
i had a similar problem W/ my tsi, the turbo oil seals were bad, u might want to check it out because it is a very common problem and it would explain you white smoke
Old 12-26-2004 | 01:06 PM
Provocateur
On permanent hiatus
I will pull the intercooler piping off and check but it sounds really fishy to be bad after only 1500 miles. Don't you think?
