JDM HID install
Old 09-04-2002 | 12:21 AM
bgood7061's Avatar
bgood7061
DO IT RIGHT THE 1st TIME
Another question ForceFedGSR,
Will my ABS computer work with a 98 ABS system if i decide to convert my ABS to a 98+??
Old 09-04-2002 | 12:24 AM
bgood7061's Avatar
bgood7061
Also how exactly have people bent their AC line to make clearance??? do they jus bend it in a way such that the cap is the only thing that moves or do they bend both lines out of the way???
Old 05-07-2003 | 05:25 AM
j-spec's Avatar
j-spec
Default solution.
yo, I have the solution to your problem, just use aftermarket Ballasts, like the Philips one, should only cost you like 300 bucks.
I run the same thing on my 96 GSR w/ 98 spec type R headlights, works perfect.
you can buy the 9006 male connectors at www.suvlights.com crimp the other side of the Philips ballast connectors, change the headlight fuses to 20amps then plug and play.
Old 05-24-2003 | 10:20 PM
slkstr2's Avatar
slkstr2
I had the same problem and what I did with mine is remove the brackets off the HID ballasts. The left side should fit within the a/c lines without bending them, but the headlights would stick out a tiny bit (barely noticeable). For the right side, you have to position the ballast some where else and extend the the wires to make it work.
Old 05-26-2003 | 12:27 PM
canuck-mx6's Avatar
canuck-mx6
I have made mine fit, I moved my ABS accumultor back and drilled new holes to bolt it down
Here is my '94 GSR.
I do not have any pics hosted of the modification, but if you need them, email me and I can send them to you
Old 05-26-2003 | 05:40 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
^ oh my GOD!!! That is the sickest integra ever
kptrulee
05-23-2006 03:57 AM
k.a.y
Prelude
7
09-04-2004 03:49 PM
JDMsong
12-05-2002 07:11 AM
RpG~^_^~LauRnO
16
10-11-2002 10:30 PM
bgood7061
08-15-2002 07:36 AM
Quick Reply: JDM HID install
