sound deadening in trunk
so the sound deadening material in the floor of my trunk is cracking and chipping away in large pieces... what should i do? im wondering if i should remove whats left of it (still a lot) and put new stuff in... if so what should i use?
Originally Posted by StreetNinja
I would say just remove all you can, if it's too noisy after that, go get a can of spray in sound deadening about $25 for dynashield, otherwise it's just dead weight
for as little weight the sound deadening adds, i see it as no reason to remove it. im more concerned about rust and damage to my trunk...
Use Dynamat
I used DynaMat Extreme in my trunk. That stuff is tight! Its really lightweight but stops rattles and minimizes road noise.
check it out here:
http://www.dynamat.com/
check it out here:
weight is of no concern h:
mine is too james. but its because water was pooling in there and getting underneath the adhesive crap.
i plan on removing the rest - see how loud it is, and then decide if i want to get dynamat.
