Buzzing noise from engine compartment
Old 08-11-2004 | 09:14 AM
JimBlake's Avatar
JimBlake
this is when you take your car to a service tech, if you're anything like me h:
Well, that's for the whole chapter, ALL those codes. Any one code might be 1 or 2 or maybe 4 pages. Lots of em are simple, like after you verify the wires are intact, you just replace a wheel sensor...
Old 08-11-2004 | 09:51 AM
LT's Avatar
LT
The deer had to die!
According to my Helms manual...
8-1 "ABS Function" has 2 probable causes - 1) "Wheel sensor signal disappears at speeds of 6mph or less", 2) Faulty ABS control unit (the ABS computer)
Old 08-11-2004 | 11:41 AM
Cure3's Avatar
Cure3
pixelassassin.net
Thanks for all the help guys, sounds like something beyond my capabilities, I'll get it looked at when its convienent.
Old 08-12-2004 | 04:00 AM
JimBlake's Avatar
JimBlake
Yeah, the Helm book says something about broken teeth on the sensor trigger rings, & verify the 4 wheel sensors are OK. But then, replacing the ABS computer is pretty easy. Just -umm- expensive....
Old 08-12-2004 | 02:31 PM
Cure3's Avatar
Cure3
pixelassassin.net
It seems to have become a more serious problem. My ABS pump started to leak and it seems to have affected my normal braking.
I started to get the buzzing noise a lot when I turned on the car and when I broke, the brakes would make a grinding noise even at very low speeds.
Since I pulled the ABS fuses the breaks seem to be working fine again. Seems that I may need to replace the pump or ditch it all together.
Old 10-30-2004 | 01:57 PM
AccordCoup94's Avatar
AccordCoup94
i have a 94 accord and i have the same problem. i had the buzzing noise for awhile and a few months back, the noise just stopped. i think i blew the pump. there is fluid in there and brakes are fine, just that the abs light is on and when i try to juper the connector.. all it does is flash the abs light 3 times. anyone have any idea what that means?
