will 00 si dc headers fit on a 00 gsr
Old 07-04-2004 | 11:51 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:cheers: Right on. As you were.
Old 07-04-2004 | 12:20 PM
Snoopy's Avatar
Snoopy
been there done that
Originally Posted by NorCal DC4
The difference in height comes from the deeper oil-pan on the B18C* motors, I think.
i think its the actual block height thats the difference :thinking:
Old 07-07-2004 | 07:38 AM
MY B18c's Avatar
MY B18c
thanks for the help. I was just asking cause my friend has 816 headers just lying around his house, so if they fit I could have just taken them thanks for the info
Old 07-07-2004 | 12:53 PM
Kai's Avatar
Kai
Rotorphile.
B18* family engines (B18A/B/C, B16B) have a 9mm taller deck, as in the actual engine block is taller, then the B16* family engines (B16A, B17A.) This is why B18* guts can't be straight swapped into B16A pattern blocks.
The exhaust manifold bolt pattern is identical, same flange.
The header will most likely rub the oilpan of the B18C, and will also not be the correct length for the rest of the exhaust.
