help!! seafoam prob
Originally Posted by 9600baud
Your sparks might have gone kaputz. It happens if you use seafoam, you should put POS plugs before doing the seafoam so you dont ruin good ones... probably thats your problem tho.
it cranks, but won't ignite... spark plugs have been changed, and the old ones look like shit... full of carbon... we're thinking it might be flooded cylinders.... any ideas?? and do i just need to drain the oil if it's flooded cylinders?
Originally Posted by pirate252
No...
If you can dump seafoam in your oil, what would be so bad if some leaked by into your oil through the cylender...
anyone from Indiana wanna come down here and help me out??
Originally Posted by TommyBDragon
quick thing here...does she have oil in the car? dont know if u checked but i had similar problems on my old car when the oil used to get real low.
fuel shouldnt be a problem. change the oil. make sure u put the right amount in. also check the oil for bubbles(white foam, not ones caused by the oil fallin into the pan) or anitfreeze. that might mean she has a head gasket problem. is fuel getting to the engine? might want to check the fuel filters, possibly change them as well. yeah oil in the cylinders is bad. never a good thing(im lookin into the problem myself). when u take plugs out, does smoke lift from the cylinder chambers?
