Problems diagnostics, Emergency...
My car died on me, 94 LS Teg... was just driving down local streets and it stalled out. Wont start at all. Turns fine, battery is strong. Plugs & wires etc... were changed recently, everything seems just fine. Help please!
Try testing the ignition coil. I have two friends that have a civic and an integra that burned out there ignition coils. Wont hurt to check. Hope everything works out cause i hate it when somehting out of the blue happens to my integra.
thanks ill add that to my list. It almost seemed like the fuel cut off so I might replace the pump... theres other things involved besides just the pump tho, anyone know what they are? Any other suggestions? I want to try everything in one try... thanks
Have someone help you, pull one of the spark plug wires, hold it near the block, and crank it, should be a spark between the wire and the block, try not to zap yourself, fire extinguisher is a handy item to have around when doing this stuff. For fuel pump, you need to see if it is putting anything out, which requires removing a fuel line, you probably need to replace the fuel filter anyway
ALL IS WELL! replaced the ignition coil after having to wait many days trying to get my rotor off... I ended up having to DREMEL the f*cker off but it came off. Whew... thanks guys!
