Slicks and wheel size
Old 02-21-2004 | 02:13 PM
98 Supercharged R's Avatar
98 Supercharged R
I was wanting to make 100% sure what the smallest wheel I'll be able to use for slicks on my R and also what size slicks anyone would recommend..is 14 inch too small for my car..oh yeah and it's setting pretty low and my big factory tires are tuckin in so I'm guessing I'll have to raise it up when I put slicks on or they will tear into my fenders.Only reason I don't know stuff this simple is because there are no other R owners even remotely in my area or 100 miles from my area
Thanks
Greg
Old 02-21-2004 | 08:31 PM
ITR41's Avatar
ITR41
15 is the smallest you can run...get some 15x7 inch wheels and call M&H for slicks you won't be disappointed
Old 02-21-2004 | 11:40 PM
98cwitr's Avatar
98cwitr
Where's the DC5R???
watch for flying axles :shock:
Old 02-22-2004 | 10:15 AM
98 Supercharged R
OH it will have upgraded ones before it touches the track with slicks on,I already watched a few of my freinds make that mistake.
Old 02-22-2004 | 08:11 PM
ITR41's Avatar
ITR41
sixtydashone on honda-tech went 10.5's all year on stock axles last year on the same set...if you launch right on a set of slicks you won't need axles
Old 02-23-2004 | 06:03 AM
e r i c s 9 9 s i's Avatar
e r i c s 9 9 s i
Lenso makes a 13" drag wheel that'll fit over the ITR's brake assembly. $285 I beleive for the two wheels... they you could run a 23" slick.. visit exospeed.com for more info.
Old 02-23-2004 | 07:44 PM
98 Supercharged R
Are you sure,I went to the site and to the wheels and saw 285 but how do you know they will clear??
Old 02-24-2004 | 01:53 PM
e r i c s 9 9 s i
Originally Posted by 98 Supercharged R
[quote:55f75f9c62="e r i c s 9 9 s i"]Lenso makes a 13" drag wheel that'll fit over the ITR's brake assembly. $285 I beleive for the two wheels... they you could run a 23" slick.. visit exospeed.com for more info.
Are you sure,I went to the site and to the wheels and saw 285 but how do you know they will clear??[/quote:55f75f9c62]
Cause my buddy has a pair that he runs on his 99 GSR... I'm ordering me up a set for my 99 SI.. The brakes are a tad bigger than the GSR & Si's so that might be a concern.. though all three cars require a 15" wheel as they're smallest. Easiest thing to do is call up Exospeed and ask them if the Lenso Drag wheel will clear the ITR's larger brakes.
Old 02-24-2004 | 02:29 PM
ITR41's Avatar
ITR41
you can run 13's on any SI or GSR with spacers. ITR brakes are a good bit bigger. you need 15's
Old 02-24-2004 | 05:59 PM
e r i c s 9 9 s i
These Lenso's can be ran on the GSR/SI's without the wheel spacers... How about this, I'll call in the morning and see what they say about the Lenso fitting on the ITR's and then we'll know a solid answer.
