What Clutch And FlywheeL??
on my 01 typeR, im boutz to get a ACT Clutch WIt heavy duty pressure plate with a street disc and a ACT 9lbs flywheel? is tat a good set?? if u got any better recommendations, please tell me , to handle high rpm n power while still reliable n comfortable.
Exedy makes a good organic clutch and flywheel... $590 shipped for the combo on http://www.coximport.com/exedy/hotsheet.html
I've had this same clutch now for about 4 years still no problems. Been through all kinds of boost, nitrous, high rpms, etc... Another great clutch if you as me.
Guest
Posts: n/a
I would caution anyone wanting to use an Exedy clutch on an ITR. There have been a number of issues/failures with this particular clutch and car. Good options to look into are ACT and Action.
On another note, I would recommend that everyone AVOID Cox Import for parts of any kind. They showed very clearly that they do not care about helping people that have had problems with Exedy clutches. They pointed the finger and claimed installation error when in fact the guys that installed the failed clutch have done well over 20 clutch installs (probably more) over the years. The posts were very childish and anything but professional. Buyer beware. There are many other reputable shops to get parts ... Cox is not one of them.
Guest
Posts: n/a
The person that had the failure is one of my best friends, Trey (ITRCA Admin). I didn't help with the installation, but the guys that did are more than qualified (one of them happened to be the '02 Honda Challenge H1 Champion who has worked on and tuned Honda for years).
The clutch went through the proper break-in period and started off fine. At a track day (that both of us attended), my friend's car started to shift poorly and got so bad that it wouldn't go into or out of gear. Tranny was removed shortly there after.
Pics were posted on Honda Tech of the disc. You could see bent PP fingers and scratches on the springs in the disc. In asking for help and theories as to why the clutch basically fell apart, Trey got nothing but grief and finger pointing from Cox. Mike at Cox even went so far as to Photoshop documents to make it appear like they came from Exedy. When other ITR owners claimed to have similar issues, they all got the same story from Cox. Keep in mind that Trey didn't even buy the clutch from Cox, so Mike really had no business flaming in the first place.
It was nothing more than a childish fight where Mike attacked anyone that gave the opinion that Exedy was not up to the standards that they should be. I would expect someone who owns a business to act professionally and offer help rather than accusations. Eventually the post was locked. I don't know if it's still in the archives or not though.
The clutches themselves may be interchangeable, but the problem seems to lie in the clutch pedal/slave cylinder of the ITR. Other ITR owners have expressed the same issue, so it's not an isolated case. I've got an Exedy clutch in my car, and for the most part it's been fine. Lately I've experienced poor shifting and an occassional grinding noise coming from the clutch. If my clutch does fail, I'll go Action or ACT without hesitation.
Long, but that's the story in a nutshell.
ahh... totally understandable I suppose
I personally have ran my clutch in my car for coming up on 5 years now and its just now starting to chatter you could say just a tad every once in a while so I'm gonna have to purchase another clutch soon I'm thinking... As far as recommendations are concerned, I personally have had good experiance with the Exedy though I'm open to try new things... Any suggestions on what exact clutch to use for a daily driven car that sees high-high RPM drops at the drag strip each weekend of the summer months?
Guest
Posts: n/a
Tony summed things up quite nicely.
There were 2 problems. The first was the clutch failed even after multiple pedal adjustments outlined by Exedy. First question is why is Exedy the only people publishing this need? No other clutch has this issue. This is a fairly common problem (PP fingers contacting throwout bearing best I can figure. Many ITR owners have this. I have read this problem as widely spread as ITRCA to Honda Tech to ITR owners posting on Club SI. There is without argument some fitment issues with Exedy.
That said Exedy doesn't stand behind their product worth a crap. Even worse though and the second issue I had was that I bought the clutch from Clutch City Online and when I posted my woes and suggestions I got insults and accusations from Mike and Cox. He was the rudest person I have encountered on a message board. Not what one would expect from the behavior of an established business person. He blamed the error on install. Not break in, INTALL. He said we aligned the clutch wrong on the splines. Exactly how would one do that?!? The installers were 2 of the most competent ITR mechanics I know, D from Honda-Tech and Jack from P1-Auto. The clutch was installed fine. The problem was described by Exedy and explained how to adjust the clutch to stop it. Despite all my adjusting the clutch failed and Mike did everything in his power including fabricating official documents from Exedy to make us look bad and prove his point. For the record the clutch was 4 months old and had 7000 miles on it and got a 500 mile break in. This was imperative since the new ATS final drive needed the break in period too.
I would say stay away from Exedy at all cost and never buy a thing you think might have a problem from Cox Imports because expecting them to stand behind their product is like waiting for pigs to fly.
Sorry that was so long. I have avoided hashing this out here but Eric you seem dead set on recommending Exedy clutches. They suck in Type-R and Tony who wrote above has one in a Civic SI and it has little to no problems most days. It might work in your car but doesn't do well in ours.
Trey
Trey
Guest
Posts: n/a
Guest
Posts: n/a
I'll be one more person who says that Exedy should not be used in ITRs, I used the Exedy Cerametallic Racing Clutch and it failed with in 7k miles. I was very upset and to this day I would not recommend anyone to use the exedy clutch in their R. I now have ACT xt-ss and like it very much- I would recommend this to most people but some people might say its a bit stiff.
I know you're gunning for 12s at the strip next year, so you'll definitely need something that can take the abuse of your impending motor build up (hooray for big cams and high compression). I'd say a 6 puck will probably be the "best" of both worlds as far as daily driving and track use is concerned. I've seen good things from ACT and Rocket and others have recommended Action, so I'd consider that as an option too. Tilton is definitely at the top of the list, but I don't even think "pricey" describes how expensive it really is ... I guess it's not bad if you consider the fact that you get a clutch and flywheel package, but it'll still hurt the checkbook.
