spun bearing!
Old 12-26-2003 | 01:11 AM
Renzuko's Avatar
Renzuko
Ok.... my 2000 Type R has only 42000 miles on it, but some how I have a wonderful sounding knock coming from around #4. Has anyone heard of this happening before :?: [/quote]
Old 12-26-2003 | 03:18 AM
Trey
Guest
Posts: n/a
Spun bearings is a lot of the time a lack of oil. DId you run the car low on oil or have moderate levels of oil and take hard repetitive turns?
Old 12-27-2003 | 09:20 AM
Renzuko's Avatar
Renzuko
Hard repetitive turns yes, low oil, absolutly not. however, after the problem is corrected I plan to get a baffeled oil pan... do these actualy do any good?
Old 12-27-2003 | 02:26 PM
BudMan
Guest
Posts: n/a
They certainly can't hurt... :wink: That's soon to be on my list this year!
Old 01-15-2004 | 03:15 PM
Big Phat R's Avatar
Big Phat R
Baffled pans make a huge difference.
I spun #3 rod bearing in my motor at the track with a full crankcase of oil.
If you run at the track - you should use a baffled pan period
Old 01-16-2004 | 04:01 AM
Renzuko's Avatar
Renzuko
turns out it wasnt either. my cai sucked up abit of water in some heavy rain. Im not sure how bad it is... Im just hoping the crank isnt damaged.
Old 01-17-2004 | 12:00 AM
bbasso
Guest
Posts: n/a
You might have bent a connecting rod, OR STRESSED it out. Be careful on your next move. Let a professional look at your motor.
Old 01-17-2004 | 12:52 AM
Renzuko's Avatar
Renzuko
hopefully thats not the case.. as soon as the knock started the car was parked. I havent delt with this sort of problem before so I am sort of learning as I go... but I guess Ill have to see.
