Accelerating Rev Problem
Old 06-09-2003 | 08:44 AM
Zodiac R279's Avatar
Zodiac R279
Sounds like a Clutch problem and I'd think that before the LSD...
If a clutch is bad after only 50k then there is some reason why.
Driver? Does the driver ride the clutch or use the clutch to slow the car all the time?
Faulty Master Cylinder? My sister had a Saturn and the clutch would always slip on the FW even if it were fully engaged. Found out that there was some problem with the master cylinder.
Just a thought. Have them check the entire system and if ther problem is with the Master Cylinder or something related then there is no question that Acura should fix the system and replace the worn disk as well.
