1990 jdm 1 piece bulbs
hi im asking for a friend. i bought my peoples the jdm 1 pieces for his 90 integra. now i know the low beams are h4h which are expensive and/or not found in the us. i think i seen them on ebay. but what are the other bulbs? and how do you change them? one of the corner lights doesn't look like it even has access to it...nor does it light up, anything even in therE? he's been running around using his highbeams for the last year, now that he wants to sell the car it would help if it would pass inspection!
thanks in advance
v
thanks in advance
v
I have the same 1 piece JDM's. I've changed the bulbs from the H4H's to H4's Brite White (blue coating) bulbs. You'll need patience, needle nose pliers and tin snips, metal cutters. I've had them in for 2 years now and they look so much better.
The fog light bulbs are H3's. Don't know 'bout the costs (My mechanic had a bunch of junked 'tegs). These pop out easily. Take off the white plastic cover (2 screws).
The corner bulbs are cheap and fairly easy to access unless you have small chubby hands. If you can't reach them with your fingers then try long pliers. Be gentle though. You have to turn them 45 degrees then they pop right out.
Putting them back in will take even more patience and finger twisting.
