Oversized or Standard pistons?
![Default](https://www.honda-acura.net/forums/images/icons/icon1.gif)
I am looking at getting pistons for my '98 GS-R. I have someone who has a set of standard ITR Pistons with rings for $200. Is it worth buying or should I go with oversized Type-R pistons. I am planning on getting a turbo soon. Or should I get different pistons than Type-R. Also they are Topline Type-R pistons, is this different than regular OEM Type-R pistons. Thanx for your help in advance.
The type r pistons will give you more compresion, so if your going for a Turbo setup then those would not be the ideal pistons to get unless you were going for NA or a supercharger setup. Get pistons that would lower your compresion.
Originally Posted by Mac8008
I think you know this, but you didn't make it clear in your post. If you go with oversize pistons, you can't go with a stock bore.
Wannabe yuppie
If you're planning on getting a turbo soon, worry about the turbo and its associated hardware before you start opening up the motor and replacing pistons. You can make plenty of reliable power on a completely stock engine as long as you have the right parts and it's tuned correctly.
ChillOutWayne
2
07-12-2003 04:23 PM
