Which one is more beneficial?
i have a 95 gsr and just put a new header (comptech 4-2-1) and i need your expertise guys on which one is more beneficial between getting a new catalytic converter or exhaust? thanks in advance for any input....learning everyday here
other people here are more knowledgable, but just save up alittle more and go with the full exhaust/cat back to draw the full potential out of your other bolt ons, and make shure it'll all fit together and you should be satisfied.
good call on the comptech header. hope it helps i'm learning here too.
given that it's a '95, it's quite possible that the cat is clogged or getting there, subsequently robbing you of some or a lot of horsepower. if that's the case, clearly replacing the cat would show you more gains. however, i don't know if there's any real way to tell without tearing open the cat. also, replacing the cat and retaining the stock cat-back might just result in little gain, assuming the original cat is ok.
that said, is there any possibility that you can do both?
Originally Posted by RiGgEdB18B1
Getting a custom exhaust will save you big bucks,so just go buy a muffler and get custom pipes done....as for the cat get a high flow cat and you will be set
Just my thought
