JDM Final Drive Installed, TRANNY TECH NEEDED *HELP*
JDM Final Drive Installed, TRANNY TECH NEEDED *UPDATED AND FIXED*
Okay just installed the JDM Final Drive, Went for the first start up and TROUBLE!!...
Okay when I start the car (clutch pressed in) and I let out the clutch (in neutral) it automatically kills my motor. AND when I put it in 1st,2nd,3rd,4th, or 5th gear and let out the clutch, it makes a weird scratching sound at first, then kills the motor once fully released. AND another thing is that it WONT go into Reverse AT ALL!!
*UPDATED* Well we get at it yesterday again, had the tranny out of the car and sitting on the ground like 45 minutes, tore it all apart, found out that the Gears on the countershaft were all binded together, the synchro sleeves or synchro's wouldnt even budge at all. So with the help of a feeler gauge and such, then put all back together. Came out good :grinpimp:
I'd venture to guess the forks are not lined up right somehow but no idea how you got the tranny back together if that is the case. I sent this to D. He helped put my Final Drive in and knows WAY more about transmission inards than I do. Hopefully he can give a suggestion.
take it back out..
xtrmcheeze
17
07-15-2002 01:32 PM
