5th gear grind at high RPMs
Old 02-03-2004 | 04:41 PM
Xymox007's Avatar
Xymox007
Björkian
Default 5th gear grind at high RPMs
If I'm traveling at 75mph and drop it down to 4th gear and then into 5th I get this annoying grind when I'm pushing from 4th gear into 5th gear. It does not happen at lower RPMs, only at higher RPMs.
What's going on here? I have a 1998 GS-R with 50K miles.
Thanks.
Old 02-03-2004 | 06:28 PM
Xymox007's Avatar
Xymox007
Björkian
A N Y B O D Y ?
Old 02-03-2004 | 07:24 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
synchro
Old 02-03-2004 | 07:32 PM
Xymox007's Avatar
Xymox007
Björkian
Okay, what does that mean for me?
Old 02-03-2004 | 07:41 PM
aphex's Avatar
aphex
driftin'
You or whoever learned how to drive a stick on your car messed up the snychros a bit all i know is that at 50k miles, your 5th gear syncrhos shouldnt be worn unless you suck at driving
Old 02-03-2004 | 07:43 PM
Xymox007's Avatar
Xymox007
Björkian
I remember the previous owner telling me his g/f learned how to drive stick on the car he sold me (GS-R). Nice. The throw out bearing was making a good bit of noise shortly after I purchased the car. Brake grease stopped that. I assume this is related?
So what needs to be done and how much am I looking at?
Like I said, it only happens on high RPM gear changes from 4th to 5th.
Old 02-03-2004 | 07:45 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
That means you either have to take the tranny to a shop and have the synchros replaced (or you could learn to do it yourself, but I would not recommend it if you have never worked on a tranny before). Or you can just find another tranny. :a:
Old 02-03-2004 | 07:46 PM
Xymox007's Avatar
Xymox007
Björkian
How expensive are these to replace?
Old 02-03-2004 | 07:51 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
If you take it to a shop it could be from $500 -$1500 depending on what they need to replace. If you do it your self the synchros are about $200 a peice from the dealer. I do all of my own tranny work so I just replace them myself but like I said I would not recommend doing it if its your first time going in a tranny.
Old 02-03-2004 | 07:52 PM
Xymox007's Avatar
Xymox007
Björkian
Nice. In that case, I can make do until Spring (read: new car).
Quick Reply: 5th gear grind at high RPMs
