5th gear grind at high RPMs
Old 02-04-2004 | 09:20 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Originally Posted by Xymox007
According to this: http://www.honda-tech.com/zerothrea...print&id=549469 many Integra owners (including GS-R/Type-R) as well as S2000 owners have had a lot of luck with GM Synchromesh clearing up their gear grinds.
I'd much rather spend $35-$50 seeing if this is a solution to my problem before I drop $350-$1500 for basically a tranny rebuild. Know what I mean?
I agree I would give it a try, as long as you know if it works it will just be a temp. fix for bad synchros.
Old 02-04-2004 | 10:39 PM
g2tegls's Avatar
g2tegls
MR, ftw
I don't think it's a gearing issue. I think it's a synchro issue. Saturday I'm buying some GM Synchromesh and hopefully that will fix the problem.
Anybody know how much of the stuff I need?
There is no "issue" with the gearing. My point was that if you are shifting at high rpm in 4th gear then you are upward of 100 miles per hour (mph). Are you hitting 100 mph so often that a little grind is a real problem?
Old 02-05-2004 | 03:39 AM
reno96teg's Avatar
not necessarily. he could simply be low on tranny fluid now.. anyhow, let us know how it works out, xymox007.
Old 02-05-2004 | 06:29 AM
Xymox007's Avatar
Xymox007
Björkian
Now I understand what you're saying. And, you're right, it shouldn't be a huge concern, because it's not like I *need* to drop to 4th gear to run up to 100mph+ very often (if at all).
I think's its my overly auto obsessed mind acting up again.
Reno, I'll def. give a full update after I pick-up the GM Synchromesh in the system. (I stll need to know how much I need. Do you know if one bottle is sufficient?)
This is my only gripe with Hondas, their tranny's. Everything else can take the abuse, with the exception of the tranny. I'm not driving the car any differently then I've driven my previous German autos. Though, I do recall getting stuck on some ice in the car wash last week which required a lot of reverse to first rowing of the gear box. Perhaps I caused my own problems when I got stuck?
Old 02-05-2004 | 07:39 AM
reno96teg's Avatar
assuming each bottle is 1 liter, you'll want 3 bottles. if i remember correctly, the tranny takes about 2.5 liters or so.. definitely over 2.
Old 02-05-2004 | 07:50 AM
Xymox007's Avatar
Xymox007
Björkian
Good lookin' out. :cheers:
Old 02-11-2004 | 02:13 PM
Xymox007's Avatar
Xymox007
Björkian
Wow, this stuff is incredible. The "snick-snack" of my shifter has returned, and the 5th gear grind has not!
AMAZING stuff. I applaud this fine GM product. :thumbup:
TaylorC01
92+ Civic/EL & Del Sol
40
09-01-2003 11:28 AM
KaoticIllusionz
Engine Swaps, Tech & Tuning
2
06-19-2003 02:29 PM
seattlex19
3
11-18-2002 01:50 PM
ludebruin
Prelude
5
08-28-2002 09:02 AM
ludebruin
5
08-23-2002 12:59 PM
Quick Reply: 5th gear grind at high RPMs
