5th gear grind at high RPMs
try changing the tranny fluid. it may help, even if just temporarily.
I don't think it's a gearing issue. I think it's a synchro issue. Saturday I'm buying some GM Synchromesh and hopefully that will fix the problem.
Anybody know how much of the stuff I need?
Originally Posted by 93HybridCX
I would not put anything in it thats not OEM. If the tranny oil is to thick you can do alot more damage to the tranny. Go to the Honda dealer and just get manual tranny fluid.
In case you didn't know the LSD is inside the tranny...So its not the same as "differentials" like that fluid is for (that fluid is for things like 4x4 trucks and AWD cars that have a differential thats linked to the tranny by a drive shaft).
According to this: http://www.honda-tech.com/zerothrea...print&id=549469 many Integra owners (including GS-R/Type-R) as well as S2000 owners have had a lot of luck with GM Synchromesh clearing up their gear grinds.
I'd much rather spend $35-$50 seeing if this is a solution to my problem before I drop $350-$1500 for basically a tranny rebuild. Know what I mean?
