Turbo kit
Old 01-25-2004 | 01:42 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by JohnQPhats
This actually brings up a question that I've had on my mind for a long time. Since and LS has great low end torque wouldn't it be better to supercharge it? Considering that a supercharger takes time to wind up and works best at high RPM? Am I mistaken?
Just for the sake of clarity... a centrifugal supercharger will tend to produce more power in the top end, whereas a Roots or Eaton-type "blower" (think JRSC) will be more inclined to help power production in the low and mid-range areas.
In any FI application, SC or Turbo, the efficiency of the cylinder head, the static CR and the cam profiles must be considered. While the stock B18B cams have less overlap than the B18C1 or B18C5 cams (duh), there is still the issue of the efficiency of the the head design and exhaust, what forms of Intercooling are used, total boost pressure, etc.
All in all, there a heck of a lot of variables, and I'm beginning to lose my train of thought. h: In short, it depends. :chuckles:
Old 01-25-2004 | 01:54 PM
forum95's Avatar
forum95
I'm Cooler than You
A turbo would have a better high end, Supercharger runs off a pulley, therefore once your crank starts turning you start boosting. A supercharger is a better low end mod then a turbo and vise versue.
Old 01-25-2004 | 05:29 PM
JohnQPhats's Avatar
JohnQPhats
LS Master
Gotchya.
Old 01-26-2004 | 09:14 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
turbo > supercharger imo. When im doing some spirited driving im not spending much time in the low - mid power range...im all about high end, engine screaming pedal to the floor driving and thats where the turbo benifits the most. I am also just beginning to look into different types of turbo kits as well but i am looking to do a complete turbo, intake manifold, header, cat, cat back system (also replacing the cams, cam gears and fuel rail) all at once. Does anyone have any idea how much all of this stuff is going to cost?? I was thinking of going with a Hondata ECU, Greddy turbo, skunk2 intake manifold, JDM DC 4-1 head (provided my 2 inch drop wont cause problems), Thermal High-Flo Cat, Thermal Exhaust with 3" piping and AEM cam gears and cams and fuel rail. I have no idea how much all this stuff costs or to have these things installed. Ill prob install everything but the cams, cam gears, fuel rail and turbo by myself and have it all tuned. I was hoping to spend no more than 7 or 8 grand on everything.
Old 01-26-2004 | 09:25 PM
forum95's Avatar
forum95
I'm Cooler than You
If your planning on going turbo, you wont need that
Old 01-26-2004 | 09:30 PM
Shore 96 Teg
What will i need?
Old 01-26-2004 | 09:31 PM
forum95's Avatar
forum95
I'm Cooler than You
What will i need?
A nice fat turbo manifold
Old 01-26-2004 | 09:32 PM
Shore 96 Teg
proving once again that i know jack sh!t about turbo setups. :rofl:
Old 01-26-2004 | 09:36 PM
forum95's Avatar
forum95
I'm Cooler than You
:exnbp:
Old 01-26-2004 | 09:44 PM
Shore 96 Teg
so im guessing that the Greddy kit would come with the turbo manifold or do i have to purchase that seperately?
