exhaust manifold (red hot)
Old 01-22-2004 | 12:58 PM
stimmel03's Avatar
stimmel03
i have enough coolant
plugs show im running lean
i dont know what to check
Old 01-30-2004 | 04:34 PM
AP2's Avatar
AP2
Moderator Alumni
Check to see if your timing is at 16 BTDC. If not, adjust your distributor accordingly.
Old 01-30-2004 | 05:44 PM
+ve psi's Avatar
+ve psi
My experience with a glowing manifold resulted from a lean burn condition caused by faulty rrfpr but that was with a turbo. The other cause, as mentioned before, is a plugged cat. The latter is the more common cause of a glowing manifold. I've been told that you can check if your cat is plugged by using a laser thermometer, you take readings at the front of the cat and then at the back. A well functioning cat will have a noticible temperature difference whereas a plugged cat will have a uniform temp. If it's not your cat then check your fpr, fuel filter, fuel pump....etc...
Good luck
