need advice about oil leak
you will have to take the valve cover off, and at least loosten the end cap on the cam shaft, but to do it correctly you'll need to loosen all cam holders evenly to do so. also is it leaking from the side nearest the pass side fender or is it near rear the firewall? if it's at the rear of the head check the oil filter(loose) area
its leaking from the pass side and its a little on the front area. the whole trans is covered with oil and when i get on it it stinks like oil. if i open my hood to show people my header they are always like DAM thats a big ass oil leak you got goin on
