b20 or b18C1
b20 or b18C1
i wanted ot know what yea a B18c1 would have to fit in order to fit in my 90 LS integra or where what year and make would i have to get for a B20 and Which would be best to turbo with the price adding up
best to turbo in my mind would be the b20b/z, simply because the low end torque of it will make up for the turbo lag in the lower RPM's. But, the only downfall of the b20 would be the lack of vtec. But, to make up for both shortcomings, you could get a b20b/z block with a b18c head, and then you'd have the best of both worlds.
Um yeah as far as reccomendations go you're going to have to be a little more specific here with what you're trying to achieve. Oh also using a little bit of capitalization and punctuation couldn't hurt our ability to understand what you're trying to talk about.
Originally posted by acuraattackura
Thank You for the imput. Sorry on my grammar. But i still dont know what year or makes to get either engine from that would fit with my car is it OBD I or Pre OBD.
Your car has a cable clutch so you have to use either your stock transmission or a cable-actuated transmission from the same cars you would get the ECU from.
As for turbo choice that depends a lot on how much you want to spend and how much power you want to make.
Originally posted by ChixWitDix
(little off topic) is the time and effort of the whole b20 block worth it? wouldn't you be better off just going turbo on you stock engine? or is it some kind of pissing contest?
b20's can be found for 700-800, so its a very economical swap, especially if you're on a budget. the only downside, in my opinion, to the b20 is that its an suv class engine, making you fail visual smog inspections anywhere u go.
i drove a b20 integra the other day and its definitely a big improvement over the LS. I like GSR's too but when people say b20's are torquey, they're not kidding.
DB Squad
Integra Forum Moderator
DB Squad
