b18a1 Vital Questions!!!!
Originally posted by menappi
ok well im going to replace the axel today, or should i just replace the boot? cause i bet it hasn thad greas, but i dunno if i should just do the boot or the whole thing. and the noise is loudest when im going slow, and its sorta a metal on metal sqeeling griding noise. i was told it was the wheel bearing..where and how do i fix that??? i cant find it in my manual.
and about the part where the transmission is connected to the core support, should i take that off if i dont want my car to shake, cause at lower rpms is SHAKES like no other. was there suppost to be a front tranny mount?
and ill post apic of my vacuum lines to see if something is wrong.
thanksss.
thanksss.
ok the boot was ripped and the guy just tried to tell me it was only the wheel bearing. the wheel had hella slack in it when i jacked it up. i took everything off and hears a pic
how do i fix this? and when i do replace it, do i get a 91 civic one? or a 93 integra one? and also the axel needs to be replaced, which one do i buy for that (b18a1) in 91 DX. and the vacuum lines i need some help with. heres a pic
one more thing. about that wheel hop stuff and how this guy welded some angle iron on the tranny to the chasis, should i take that off? do you think it will stop the vibrations of my car? i thought the engine is supposed to have a little moving room?
