Radio code
Im almost positive if you take off the fuse box cover in the engine bay and look underneath the lid you will find the code there. I had the same problem and took it by the dealer and they showed me how to do it.
Dilbert21... Even though they don't sell Integras, did you try the Honda dealer anyway? They might be plugged into the same computer system to look it up??
on my 2000 gsr the radio code is on a sticker on the outside/left side of the glove-box.
i have read threads that say the sticker is sometimes on the bars that hold the trunk lid up.
When you turn the radio on after the power was pulled it will say "code". If your code is 12345 you press the buttons in this order "1-2-3-4-5", the radio will beep and turn on.
That's it.
The only reason the stickers are on the car in anyplace is because the dealership may put them there. The cars do not come from the factory with the stickers anywhere but on the card they are supposed to be on. There is NO PLACE ON THE CAR THAT THE RADIO CODE IS STAMPED FROM THE FACTORY!!!
That's it.
i dont know if anyone has already said this b/c i dont feel like reading them all so...this happened to me. i was told that when the car roles of the truck at the dealer the put a sticker or write it on the car somewhere. so here are some places i was told to look....pull out the ashtrey look on back and sides for a sticker, there is also a trey on the back of the console look there, then i was told to look under the hood near the vin numbers and under the fuse box. good luck
