Redline on an LS
Old 11-07-2003 | 09:51 AM
Legend_master's Avatar
Legend_master
Never fast enough member
Default Redline on an LS
Hello all, my friend just put an LS motor in a 96 civic and we are not sure where redline is on the motor. Please let me know so We can officailly prove that I can beat him.
Thanks
Old 11-07-2003 | 09:54 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Depends on the year of the motor. For an OBD II (96-on) B18B, the redline is 6800rpm.
Old 11-07-2003 | 10:08 AM
Legend_master
it's a 95 obdI
Old 11-07-2003 | 10:20 AM
TheOtherDave™
Apathy Kills
Originally posted by Legend_master
it's a 95 obdI
Then, if memory serves, the redline is at 6400.
At any rate, you're looking at about 135hp at ±5900 or so out of that motor.
A rough estimate.
Old 11-07-2003 | 10:24 AM
dubcac's Avatar
dubcac
I
142 hp @ 6300 rpm
127 lb-ft @ 5200 rpm
Redline should still be 6800 rpm, however fuel cutoff is 7400 rpm I believe, whereas on the 96+ it was 7200 rpm. Anyhow, I wouldn't take it much past 7k, you arent making power up there anyways.
Old 11-07-2003 | 10:56 AM
Spec R's Avatar
Spec R
Originally posted by dubster99
142 hp @ 6300 rpm
I dont go that high up that often but last time I remembered that it was NOT 7200, more like 7000 rpm...maybe its just my tach or car. :dunno:
DB Squad
Integra Forum Moderator
Old 11-16-2003 | 12:46 PM
spooncivicb16b's Avatar
spooncivicb16b
6900 i own a 94 integra
Old 11-16-2003 | 04:57 PM
infamous1se619's Avatar
infamous1se619
6900 redline. 7100 fuel cutoff
Old 11-16-2003 | 08:30 PM
ska32198's Avatar
ska32198
i redline at 6800 and thats a 95 SE Auto not sure bout the fuel cut off tho
Old 11-16-2003 | 10:37 PM
Takumi Fujiwara's Avatar
Takumi Fujiwara
I own a 94 LS, where you see the "red" on the tach is where you're going to hit the fuel-cut-off.... about 6800RPM.
