Redline on an LS
Originally posted by dubster99
142 hp @ 6300 rpm
127 lb-ft @ 5200 rpm
Redline should still be 6800 rpm, however fuel cutoff is 7400 rpm I believe, whereas on the 96+ it was 7200 rpm. Anyhow, I wouldn't take it much past 7k, you arent making power up there anyways.
142 hp @ 6300 rpm
and my friends 94' RS redline is at 6800 rpm as well .. i have a 2001 model~~ fuel cuts off at 7100 RPM
Originally posted by LT6916
94-99 LS tegs had 142 @ 6300.
00-01 LS tegs had 140 @ 6300 due to the revised OBD-II ECU.
92~95 OBD1
96~99 OBD2
00~01 OBD2V2
Stop giving the faults info
i dont' know where you got that crap up there~ 140HP?
Godsh what happened to Honda-Acura these days..
this topic has been brought up million times.. (2+ year ago)
you guys should really use the search key
Bseries engine spec.
wow...that is off! unless you downshifted at the wrong time and over-revved the motor hnoes:
I hit my rev limiter in my LS @ 7100...redline is 6900.
get real man..
so you are saying you have a special made 1994 integra NOnVtec made by Acura?
stop giving the faults info.
everyone knows 96-99 Integras had OBD-II...the REVISION of OBD-II in 00 knocked the horsepower from 142 to 140. I'm not giving "faults" info. And my tach does say 6900 - its right infront of me while i'm driving
