<><> Selling everything! LS tranny, camber kit, turbo parts, and more! <><>
Old 09-11-2005, 06:15 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Default <><> Selling everything! LS tranny, camber kit, turbo parts, and more! <><>
Alright everyone, the car is gone and now I'm cleaning out my garage. I have a bunch of bolts for most things on the car so let me know you need something. Everything listed here is OBO and + shipping. Serious inquiries only!
1992-1995 Civic Sedan Authentic Honda OEM full bra (hood & bumper) - used the hood cover only for one month - $125
JDM ITR Cam sprockets - $30 for both
92-95 Civic fuel filter to fuel rail line (had 2) - $5
Venom dipstick - $5
92-95 Civic OEM Master Cylinder & Booster - $20
92-95 Civic USDM clock - $25
Civic/Teg Coolant Reservoir cap - $2
B18C1 Crank sprocket (for timing belt) w/ washers - $5
D15B7 Distributor - $40
92-95 Civic emergency flasher switch - $10
94-01 GSR gauge cluster (odometer needs fixin') comes with plugs - $65
92-95 Civic / 94-01 Teg Ingalls front camber adjusters - $50
OBD1 injector clips (4) - $20
92-95 Civic sedan OEM Honda mudflaps (front and rear) - $50
92-95 Civic / 94-01 Teg (might fit 96-00 Civic) rear motor mount - $10
Apexi N1 N/A silencer - $20
92-95 Civic Manual Tranny Starter - $10
92-95 Civic Sedan inner tail lights with wiring - $15
Integra A/C mount (P73) - $20
Sparco hood pins - never used or even opened the package - SOLD
Integra GSR steering column w/ ignition (has key), plastic cover, brace, and signal/wiper arms - SOLD
Full A/C system for the '92-'95 Civic up to the line connections behind the pass side headlight - SOLD
2 steel braided lines - one is 3' and other is 20" - SOLD
GSR valve cover with the cam cover cut off - used for tuning - SOLD
Bseries upper cam mount bracket - SOLD
92-95 Civic DX wiring harness (cut, but good for the connectors you might need) - SOLD
1992-1995 Civic EX OEM header w/ O2 sensor - SOLD
LS Tranny - ~40k miles - perfect condition - SOLD
2 TiAL 2-bolt wastegate flanges - SOLD
Exhaust Cutout piping w/ 2 flanges - SOLD
B18C / B16A DC Sports polished spark plug wire cover - SOLD
B18C1 Cams (OEM) w/ sprockets - 60k miles - SOLD
Integra alternator mounts - SOLD
Bseries upper cam mount - SOLD
92-95 Civic OEM shifter - SOLD
92-95 Civic shift rods - SOLD
B&M fuel pressure modifier (FPR) - SOLD
92-95 Civic fuel filter to fuel rail line - SOLD
94-01 GSR dash fuse panel - SOLD
Autometer Z-series boost gauge (no line, just gauge) - SOLD
Autometer Z-series mechanical oil gauge (new in box, never opened) - SOLD
Greddy 9mm oil catch can - SOLD
Generic oil catch can w/ drain and filter - SOLD
2 15x6 Konig Heliums (11 lbs - 4x100) w/ 205/50/15 BF TA Drag Radials w/ lots of tread left - SOLD
92-95 Civic DX (D15B7) Manual ECU (P06) - SOLD
Civic AC Mount - SOLD
92-95 Civic (Canadian) DX cluster (in kph) - SOLD
PM or post
Old 09-12-2005, 07:59 AM
westcoaststyle
wire cover sold
Old 09-12-2005, 08:14 AM
westcoaststyle
ECU sold
Old 09-12-2005, 09:46 AM
westcoaststyle
Drag rims/tires, greddy can, gauges sold
Old 09-14-2005, 07:14 PM
westcoaststyle
cams, civic a/c mount sold
Old 09-14-2005, 08:22 PM
pomansouth
pomansouth's Avatar
i can vouche for the tranny and a good man that is selling the tranny, the tranny is perfect, no grinds and has 43k miles on it, it came out of my 98 acura integra...
Old 09-16-2005, 11:00 AM
westcoaststyle
alt. brackets, bseries mount, fuse box sold
Old 09-17-2005, 08:49 AM
westcoaststyle
items added/updated
Old 09-17-2005, 10:07 AM
extensioncordy
EG6
extensioncordy's Avatar
what would shipping be for the EX manifold? 44035
Old 09-19-2005, 07:18 AM
westcoaststyle
tranny sold
