Hesitation and Enigne Codes...
Old 07-15-2002 | 10:25 PM
ChillOutWayne's Avatar
ChillOutWayne
Default Hesitation and Enigne Codes...
A week ago i installed my Apexi WS catback and a test pipe...ever since installing the exhaust, when i start out in first gear and sometimes in second when the engine was just started after cooling down completely, i just a odd hesitation at low rpm only in first or second gear, i can only explain it as a low growl tone and when i hit the gas it will briefly rumble a little more then move on and accelerate normally...but the weird part here is that after that initial little stint, it never happens after that...not until the motor has cooled completely and restarted...on another note but possibly related the MIL has come on twice, but when i pull over and restart the car, it goes off...and just today i learned about the codes and tried that and came up with 16 and 43...fuel injectors and fuel supply system...my question here is is this most likely related, and if so why only just after i installed my exhaust and whatever? also does this mean i absolutley have to replace the injectors, and the fuel pump for the supply system, or could it be fuel filter or plugs/wires related??? i appreciate whoever reads all the way thru this and thanx in advance for replies
Old 07-16-2002 | 12:57 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Sounds O2 sensor related, sicne you just put a test pipe in...
Old 07-16-2002 | 09:58 PM
EG6's Avatar
EG6
What yr is the car??? 96+?? It sound like you messed up the 2ndary O2 senor....prob just the plug got pulled. Seen it happen many of time if you're not carefull.
Old 07-19-2002 | 11:45 AM
ChillOutWayne
nah its a 94...im sure its O2 senson related now, thanx
Old 07-20-2002 | 07:31 AM
LxAccord97's Avatar
LxAccord97
is it easy to fix it yourself?
Old 07-21-2002 | 08:44 AM
ChillOutWayne
well as long as its the O2 sensor yea it should be...its just a sensor that sits in the catalytic converter, or test pipe in my car, and just screws out then the new one in
raiden571
92+ Civic/EL & Del Sol
41
12-12-2005 11:09 PM
teg92
2
10-09-2004 08:34 AM
Phat8186
Engine Swaps, Tech & Tuning
07-13-2003 11:08 AM
honda4life
Accord
4
09-23-2002 03:53 PM
bluedream
11
07-03-2002 08:39 PM
Quick Reply: Hesitation and Enigne Codes...
