Enigne Prob
Enigne Prob
Ok here the prob my engine doesnt seem to be performing up to parr. Here is the symptoms I used to be able to hold 2nd gear to about 60 and 3rd gear to about 90. Now whenever I try to do that in either of those gears the car will litterly jump as if it just down shifted but i ddint. So i will be doing 50 in 2nd when I used to be able to 60 and the car will jump as if there was no more powering to it. The same with 3rd gear. I can no longer rev in those gears. What can be wrong with my engine you guys. I also figured Ill tell you my egr valve is shot also I have have a exhaust leak on the rear tail end of my exhaust will that play an after on what is happing.
I drive a 96 honda accord VTEC. What are somethings that i can do to check my enigne make sure it is aight.
