Will 97+ teg brake master cyl work in a 94 teg?
Old 06-15-2003 | 01:13 AM
94integrals's Avatar
94integrals
Default Will 97+ teg brake master cyl work in a 94 teg?
Does anyone know if the 97+ master cylinder will fit my 94 Integra? One person I talked to said it won't, but I can't see why it wouldn't. A strut bar I already purchased won't fit over my 94 master cyl, but it will fit over the 97+ Please help me. Thanks a lot!
Old 06-15-2003 | 01:14 AM
94integrals
I found this image of the two types, but I'm still not positive whether it will fit.
Old 06-15-2003 | 01:59 AM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
i would check volume before you started swapping that around...if you have a big tank...im guessing you have drums on the rear. the drums need extra volume that a 97 for sure wouldnt need...im almost certian those would have disk brakes on the rear...just things to think about before you swap things like that
Old 06-15-2003 | 03:03 AM
94integrals
Actually 94-01 Integras all have 4 wheel discs... Thanks though.
Old 06-15-2003 | 08:34 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
i think as long as its abs/ non-abs compatible, it should fit. The brake booster itself is identical between those years. So if your car as abs, get the abs one, and if not, get the non-abs one.
Old 06-15-2003 | 11:17 AM
silverstreakin
TRD japan ownerages
wasnt sure..sorry just trying to help
Old 06-15-2003 | 03:15 PM
qtiger's Avatar
qtiger
It will fit physically but you might have to reroute some brake lines.
