Injector cleaner - this stuff is the best!!!
Old 05-11-2003 | 02:00 PM
96GreenCivic's Avatar
96GreenCivic
I'm a noob so forgive me. Did you just put the seafoam in your gas tank? I really don't know how to take out injectors, but would just putting it in the tank work ok? I usually use STP injector cleaner . How does this new stuff compare?
Thanks
Old 05-11-2003 | 04:36 PM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
I've tried all the other regular stuff before, but seafoam seams to work much better at getting rid of carbon deposits - the thing you want to remove in the first place from your engine. As long as you don't have any engine running issues right now, it would be good enough to just throw in a can of this stuff per 5 gallons of gas... so about 1 and a half cans will do it for a tank. Try to drive a lot of freeway - this works best since the engine is hot and will more likely burn off the accumulated carbon.
Old 05-12-2003 | 07:33 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Hmmm., Have to try soem in the old Prelude first. Thanks for the info. The prelude idles like crap and has new everything.
Old 06-13-2003 | 04:57 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
sorry, i know this is an old post but i just started hearing about this seafoam stuff. anyone else had any good experiences with it? im thinking about trying it but dont know about putting some into my cylinders directly.
Old 06-13-2003 | 07:02 PM
ek97hatch's Avatar
ek97hatch
hehe i always thought those solutions don't work. does the seafoam cost more compared to other popular brands? I never really did pay attention to those so i don't know. I should look into it. btw- thanx for sharing your experience!
Old 06-14-2003 | 08:36 PM
Kai's Avatar
Kai
Rotorphile.
Originally posted by doctorsohc
Just when I thought it might be just another piece of crap additive like Marver Mystery Oil.... was I wrong!
MMO is not a peice of crap, it is actually very useful in it's own niche.
Old 06-16-2003 | 11:13 PM
Spood's Avatar
Spood
Sucka
Originally posted by T-RO
If we dont have something that can tell us CC's should we just skip the part about putting some in the sparkplug hole? Or should we put a teaspoon, or tablespoon full in each?
5cc = 5ml = 1 teaspoonful
15cc = 1 tablespoonful
Old 06-18-2003 | 10:06 AM
jung4g's Avatar
jung4g
Asianalize your car
He knows, he works at a pharmacy!!!
Jung
Old 06-18-2003 | 09:51 PM
Spood's Avatar
Spood
Sucka
:thumbup:
Old 06-23-2003 | 03:19 PM
EdyJun's Avatar
EdyJun
Hey guys, I found this in one of the forums (this is part of a long discussion) and had some questions about how to inject the seafoam in the car.
“….could also get some Seafoam Cleaner for your Throttle Body. Its easiest found @ NAPA. Its in a tin can, and the can is white. its called deep clean or something. You just take this, and with one of the vacuum hoses that you took off when you put in the CAI, just put the hose back on, and you get the car up to normal temps, and just suck a little through the hose(cuttin the tip of the hose is the easiest way to do this, like @ 45 deg. angle. ) And you should suck up about 1/3 of the bottle. then just put the hose all the way in, and it will stall out. wait for at least 5 min. to let it soak in. Start it back up, and it may take a couple trys, and just let it sit and smoke all the shit out the exgaust. make sure you are outside when you do this, it will smoke for a while. “
where do I find this hose the he talks about and is my car going to shot off my itself.
I did this on my 4g, and it ran ALOT smoother
