sorry didnt read it i guess but its there..... just get another hose and loop them back toghether. its ur speed sensor you can pull it out and replace it if u need to with another one but its not needed.
so what runs through the hose... should i be missing alot of fluid because of it being broken???and also how do i check my trans fluid bcuz i dnt see a dipstick on my tans???
is there fluid all over the place and if soo u check ur level by getting the car up level on jack stands and removing the plug above and back alittle from the pass axle. it should only just barley come out if none comes out stick ur finger in and point it down a little if nothing then u need more honda fluid. but what does this have to do with ur clutch going outif ur going to change clutch then u should change fluid anyway.
There are no dipsticks on the manual trannies...
The correct fluid level is obtained by filling the tranny with oil to the top of the filler hole...
