Is the 96-99 Intake Manifold Throttle Body, and Injectors better than a 92-95?
My friend just did a swap on his 96-99 Civic EX. He gave me his complete intake manifold with throttle body, fuel rail, and injectors. The motor had only 48k miles on it. I was told that this setup will lead to better air flow and more fuel if I swapped it on my 92-95 Civic EX motor. Even if it is minimal horsepower I don't mind. Every little bit helps racer like myself. I also heard that the wiring may be different because of some extra sensor and the OBD2 ECU it came off from. I am just hearing so much different sh*# that I don't want to install the intake manifold and then I throw a check engine light. All replies are appreciated!!
Also would I need the fuel pressure regulator or an aftermarket unit for the new injectors???
:dunno:
The inside of the D16Y8 manifold doesn't look like anything special to me. It actually looks pretty rough, so I don't think it'd flow any better than a D16Z6 manifold. As for the fuel rail and injectors, the Y8 rail has the FPR on the opposite side I believe, so you would probably need to extend your return line, but like the manifold, I doubt it flows any better than a Z6 rail. As for the injectors, they're 240cc like most other Honda injectors(including the Z6's), but they're OBD-II, which means the clips are different from the Z6 injectors clips(OBD-I). If you're looking for Y8 parts that'll give you a little more power, look for a Y8 head. The Y8 head has a square combustion chamber and yields slightly higher compression than the Z6, and I also think it flows a little better. This is most of the reason why Y8's are rated at 127hp and Z6's are rated at 125.
ajusaf
CRX & Pre 92 Civic
5
11-03-2004 12:38 AM
jdmhotboy
08-19-2003 09:07 AM
Blizzard
12-06-2002 05:26 PM
