1.5L d15 non vtec able 2 swap into 99 1.6L d16 vtec sohc coupe EX ;same bolt pattern?
two posts and they are both the same useless crap.
What exactly are you looking for? Be more specific.
Motor mounts are the same, lug bolt pattern is the same...what bolt pattern are you looking for.....You could have had your answer at about 6:51pm had you done a bit of research on your own.
