96 civic to integra motor swap
hey i have the timing belt post , i was wondering how easy it is to do this swap.
does everything bolt right up?
to specify i have a 96 honda civic ex 2-door with a 5-speed.
biggest question does the tranny bolt right up, and what clutch would i use integra or civic?
also the exhaust manifold?
which one?
which one?
no the d series tranny will not bolt up to a b series motor... you need stuff for b series motor... youl need new well dont have to be new but different motor mounts a different ECU shift linkage, axles, the intake and exhaust manifold have to be for b series motors... after that tho u can use ur current exhaust hope that helps a bit
btw do the swap lol its better then the d... asuming engine is in good condition
