B16A not running right Please Help
We just had a first gen b16 put into a 95 civic dx coupe. The motor has been completely rebuilt with new ctr oversize pistons/ crane stage 1 cams/ crane titanium valve springs and retainers/ all new gaskets- bearings etc.../ and we used the obd1 sohc vtec ecu (p28 i think) that has been remapped. The motor now starts and idles ok but will not rev above 3,200 rpms. It seems like it starts to choke at that point. 3 error codes show up -- 1 for a fuel injector and 2 for the vtec solenoid. Those don't seem like problems that would limit the motor from revving. When starting fluid is sprayed into the intake man the car will rev much higher --- Anyone got any ideas? or seen this before???? PLEASE HELP -- we've spent so much on this engine already. oh -- its running on a gsr distributor and injectors.
HELP HELP HELP HELP!!!!
thanks guys
thanks guys
Originally Posted by civicsirnos
two codes for vtec and 1 for injector, can't use the b16ecu - it's obd0 and the motor has been converted to obd1 to match the car.
