valve adjustment question
Old 11-09-2004 | 06:53 AM
redteg's Avatar
redteg
Default valve adjustment question
I am doing a valve adjustment on a b18b1 and I only have angled feeler gauges that start at .005 in. How can I insure that i adjust them to spec (.003-.005). Should I adjust it so the feeler just barely does not fit in?
Thanks
Old 11-09-2004 | 07:39 AM
JimBlake's Avatar
JimBlake
It makes sense if you have no choice...
But why don't you just buy feelers that go thinner? They're not that expensive & it's better. The angled kind isn't absolutely important, that just makes it easier. It's more important to get the right thickness.
Old 11-09-2004 | 09:27 AM
jr97civic's Avatar
jr97civic
how do you do that ?i'd like to do it on my civic , if you can post a diy somehow would be great !
Old 01-27-2005 | 12:47 PM
JL95AccorD's Avatar
JL95AccorD
take off the valve cover
turn crank to get cyl 1 on tdc
adjust intake and exhaust valve clearance for the cyl to spec
rotate crank 90 degrees and repeat adjustment on cyl 3
rotate 90 degrees and adjust cyl 4
scratch your ass cuz it seems so easy to do it by now
rotate and adj cyl 2
slap on a new valve cover gasket
put valve cover back, wires, ground wire, etc.
wash your hands
go out and race
Old 01-31-2005 | 06:09 PM
olly-civic's Avatar
olly-civic
i hate noisy b18,18's they tap and tap like buggery and sometimes all the adjustment in the world wont help
