Crank pulley bolt: reverse thread?
Old 07-11-2005 | 07:29 AM
mberndt's Avatar
mberndt
Originally Posted by lingerbw
yessssaaaahhh.... I got the bolt off last night.
The hardware required:
(2) 10" 1/2" drive extensions (these came out past the wheel, so I was pulling outside the body of the car.
(1) 19mm 6pt deep socket (1/2" drive)
(1) 12" 1/2" drive braker bar
and the big dog:
(1) 5 foot length steel pipe
At first I was nervous with the ability to apply this much torque to a bolt. So, I started pulling, slowly at first. By the time I busted that bolt loose, I was really rocking back on the end of that cheater pipe. I can't imagine the amount of pressure that was being applied at the bolt. Anyway.... I'm very happy. On with the head gasket and timing belt job!! :thumbup:
My wife took some pics of the setup I had... I'll scan and post when I get them developed.
The amount of so called "pressure", which is actually called Torque, is a measurement of twisting force, which is applied to the bolt as a function of the force and the moment arm... (50lb)*(5ft) = 250 ft-lb of torque...
So, the longer the arm, the less force required...
But if you use a small ratchet, like a 3/4" drive, the force is spread out across less area, which increases the torsional and shear stresses, to the breaking point, in your case...
Also, you say you were really rocking back and forth on the pipe, there you can see and feel the deflection of the materials, steel in this case which is very ductile for the most part.
Later,
Mike
Old 07-15-2005 | 10:21 PM
flatliner's Avatar
flatliner
Fix It
once on a 92 teg i did a timing belt (10 years ago in 2ft of standing water) I had to use a 4 foot pole over my 1/2 in breaker bar and when it cracked loose, the pole was bent. Welcome to HONDA
Old 07-18-2005 | 03:05 PM
qtiger's Avatar
qtiger
I've never had a problem taking the bolts off. Moroso tool and a NAPA breaker, easy easy.
Old 07-25-2005 | 09:51 PM
blanchae's Avatar
blanchae
Default Webpage shows how to do it
I had a similar problem with a Honda Civic, so here's a webpage that details how to loosen the crank pulley bolt:
http://www.cadvision.com/blanchas/54pontiac/honda.html
Old 07-26-2005 | 09:52 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
That's great and all, but it puts uneven pressure on the pulley and will likely bend it depending on the amount of force. I would recommend getting the correct tools for the job.
Old 07-26-2005 | 11:07 AM
mberndt's Avatar
mberndt
Man, that is another stupid idea, LOL.
Get the right tools, I.E. a chain wrench, and it couldn't be simpler.
Old 09-24-2019 | 02:25 PM
Nicky Hurshman's Avatar
Nicky Hurshman
I'm going to get laughed at for reviving such an old thread but I couldn't resist (made an account for it and everything)
you're right... to an extent. torque is measured at the fulcrum point, but when you add extension bars (socket side) you're also reducing the torque you're applying, a lot of the energy being applied gets stored in the extensions and therefore you're not getting the torque you're quoting.
proper torquing is achieved with a torque wrench and no extensions... once you start adding cheater bars or extensions you might as well just use a normal ratchet/breaker-bar.
timcapo300
3
12-27-2007 06:36 PM
MaxOctane
30
12-15-2005 01:02 AM
icyfingers
CRX & Pre 92 Civic
3
01-04-2005 01:07 AM
2-accords
Accord
10-04-2004 08:18 AM
AwwsChwA
Engine Swaps, Tech & Tuning
2
06-11-2003 06:07 PM
