Shaving Honda Emblem
Old 08-01-2005 | 10:13 PM
topnatchteg's Avatar
topnatchteg
bondo and fiber glass worked fow my integra emblims and itll work for yours jus like everyone is sayin bodo den fiber den sand den paint if you ganna get it painted jus prymer it lol
pretty simple
was about an hour for me ow so jus havin to wait fow da bondo to dry is the hard part lol am i right also sometimes sandin is a pain lol
ight late
Old 08-02-2005 | 12:20 PM
digitalmethods's Avatar
digitalmethods
Depending on how quick of a fix your looking for. I took small 3m sticky blocks and adhered them to the back of the holes and then used touch up to color them. Then I cleared the touch up. It came out fine and it was a real quick fix. It will do until you do it correctly as stated above.
Old 08-02-2005 | 01:57 PM
delsol161's Avatar
delsol161
that's totally wrong. you never ever fill a hole w/ boddy filler. once moisture gets in behind the sheet metal, the filler will crack out and you'll get monster rust. if you want it done right, weld the holes, then use body filler. don't use fiberglass/resin because it expands & contracts @ different rates @ different temperatures than filelr and steel. don't cut the corners when it comes to your car's body.
