brade pad installation gone bad!
You do not want to use a C-clamp on the rear caliper because you have to screw it in to get it to retract. A C-clamp will only press it in and that won't work. I also use a screwdriver. Instead of using it as you normally would, lay the screwdriver on its side and use it long-ways in the groove. It gives you more surface area and the right size screwdriver will lay perfectly in the groove giving you great leverage. :goodjob:
hih
hih
Originally Posted by honura
A hammer!
Out of curiosity, what was the article that you followed? That should have been addressed. Also, applying your brake pedal with the brake assembly apart isn't a great idea. As you saw, your piston will slide right out, as there's no object or force retaining it in.
It's better to use the tool on the rear to make sure that you are not going to tear the boot. Tear the boot or get the boot crimped up (which leads to seized calipers) will mean to get a new caliper. Better to spend the $9 at Napa.
http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
Originally Posted by Daniel
You wouldn't want to hammer in the rear calipers. Follow Josh's method, that works! :thumbup:
I was joking around!
