High Temperature Paint
Old 03-28-2004 | 10:52 PM
black_ser95's Avatar
black_ser95
no problem, good luck
Old 03-29-2004 | 03:56 AM
Duff Man's Avatar
Duff Man
Duplicolor comes in 500f up to 1100f in the spray cans. You'll only find aluminum shades in the higher temp paints. I used an aluminum spray for my old hedder (Dupli-color) and it turned out great - 4 winters
Old 03-29-2004 | 04:31 AM
1992CivicSI's Avatar
1992CivicSI
Don't Conform, Innovate
SWEEEEEEEEEEEETTTT Thanks Man!
Old 03-29-2004 | 02:41 PM
layzie298's Avatar
layzie298
wouldnt any high temp paint work. i painted my intake tube with the highest temp paint i could find. i heard it helps keep the pipeing cooler. not sure but it need to get painted anyways so i just tried it
Old 03-30-2004 | 10:31 AM
1992CivicSI
Not sure. How is the paint holding up on your intkae and how long has it been on there. I just don't want the crap to start peeling and flaking like a month after I do it. What brand did you use? Did you use a primer too?
Old 05-08-2004 | 11:44 PM
black_ser95
anything yet?
Old 05-09-2004 | 09:07 PM
ryceryder85's Avatar
ryceryder85
engine enamel at orchard supply hardware?
Old 05-09-2004 | 09:46 PM
1992CivicSI
Well...I went to walmart and found the high temp paint. Duplicaolor 1200 degree in blue. Also got the clearcoat to go with it. Painted my exhaust manifold heat sheild and it looked great. But I baked it in the oven like the can said and it bubbled up. Now I have to resand it and paint again. I accidently set it on broil instead of 600 and it screwed it up. After I readjusted the temp in mid bake it started doing fine. I will post pics by the end of the week when I finish.
Old 05-09-2004 | 11:45 PM
Outxider's Avatar
Outxider
X-Motoring
use VHT caliper and drum paint. its better then the high heat stuff. made to withstand 1400f. good stuff.
Old 05-15-2004 | 08:37 PM
copperfox's Avatar
copperfox
nubsos
"...accidently set it on broil instead of 600"
ROFL.
sorry.
hahaha
JERZY-STYLZ
Do It Yourself
22
06-12-2005 07:34 PM
Jason C SBB
6
10-17-2003 12:36 AM
Yungstrykr
04-23-2003 09:49 AM
Diabolik
4
09-10-2002 03:18 AM
Quick Reply: High Temperature Paint
