INstall help coilovers and shocks.
I drive a 2000 integra LS 2dr.
Hi, I bought skunk2 coilovers and kyb agx shocks. I plan on installing them soon. Can any body give me any basic steps and tips and advice, like things to watch for when I am doing it. Thanks
college kid
nice setup :goodjob: i've got agx's and cheap coilovers, but over this summer i'm gonna pick up some sk2's.
wish i could help, but i'm also a little unsure of this stuff
"Local Neighborhood Pimp"
It may be time consuming and a biatch but it can definatly be done.
*Step One
Jack up the car and set down some jack stands.
*Step two
take off the wheel
*Step three
remove the stock strut and spring( you need a spring compressor)
*Step four
Assymbol the coilovers on the new shocks
*Step five
Reinstall the unit.
*step six
repeat steps 1-5 on all four assymbolys and proceed to adjust your ride hieght.
*step seven
put the wheels on and take it for a test drive.
*Step One
*Step two
take off the wheel
*Step three
*Step four
*Step five
Reinstall the unit.
*step six
*step seven
Make it seem so easy.. like my good friend Butt-Head says.. "u need the right tools for the job, beavis".. i would say if u have machanical skills it would take u 6 hrs.. Much harder than 6 steps.. try 20 steps.. that is just a brief intro.. no details..
Details should come with the shocks and coilovers. Strut removal and installation instructions can be found in good detail in the Haynes book foryour car. If you have a friend who has been through this process call him over to assist you. The only tools you won't usually find in your own tool box would be the spring compressor and that can be rented from autozone. He is right thogh about it getting tough so if your going to do the job you need to be completely dedicated to it. It's not one of those projects you can just stop and drive to your friendly local import speed shop to install. Regaurdless it is good to learn the steps on how its done. Look over the instructions and decide wheather or not you want to put that much work into this project.
What ever you do be careful with the bolt on the bottom of your strut/shock. If you break the head off its a pain to get it out and then you will have to drill it out which will 99% of the time mess up the bushing. Definately call someone to help cause it is easy if you know but time consuming if you don't.
^^That's Me!^^
college kid
can anyone help me with the assembly of the coilover, and how it gets seated onto the shock.. this part is what i am most unsure of.
if need be i can take pics of all the parts that came with my coils and pics of my agx's
it should be pretty self explantory if you just look at the mechanics of the coilover. Make sure the coilover adjuster is under the spring so you can twist it and raise it or lower it and so forth. Also make sure you have the cap on the top. You should be able to look at it and figure it out.
