Remote start alarm inst., 93 civic hb elect. wiring dia.........do u have info?????
i need wiring information for a 1992-95 civic hb........i need voltage polarities.....and wire colors and all that stuff needed to help me with the install of a REMOTE START ALARM SYSTEM! any info is greatly appreciated!!!
help me ....please!!!!
thanks in advance,
jophes
1992 civic
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |brn conn abv fusebox |
| STARTER|black/white |+ |brn conn abv fusebox |
| IGNITION|black/yellow |+ |brn conn abv fusebox |
| ACCESSORY|yellow |+ |brn conn abv fusebox |
| POWER LOCK|green/white |- |in drivers door *2 |
| POWER UNLOCK|green/red |- |in drivers door *2 |
| PARKING LIGHTS +|red/black | |grn plug top of f-box |
| PARKING LIGHTS -|white/black | |anti-theft module *3 |
| HEADLIGHTS|red/white (low only)|+ |steering column |
| DOOR TRIGGER|lt green/red |- |driver kick panel |
| TRUNK/HATCH PIN|grn/blk 2 silv dots |- |blu conn above fusebox |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| TACHOMETER|blue *1 | |2-pin plug near distr. |
| BRAKE WIRE|green/white |+ |brake pedal switch |
| HORN TRIGGER|blue/green *4 |- |steering column |
| WIPERS|blu(low),blu/yel(hi)|- |wiper switch |
| LF WINDOW UP/DN|red/yel - red/blu |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp |
| LR WINDOW UP/DN|grn/yel - green |A |in drivers door or dkp |
| RR WINDOW UP/DN|yellow - yel/grn |A |in drivers door or dkp |
Notes:
*1 Also at round gray connector next to hood strut.
*2 Door lock module in door above the speaker. the wires can also be found at the anti-theft if equiped.
*3 the anti-theft module is located under the drivers seat. only some models are equiped with anti-theft.
*4 can also be found blue/red at anti-theft if equipped
Hope this helps, and should get you started. I gathered this info from other sites. Should work for 1992-1995, my other diagrams then go from from 1996-1999/2000, so i am thinkin this info is for that generation. Let me know if you need anymore info or help.
Notes:
I have the wiring info for a bunch of civics from 1992-2003, and can probally get other cars too. I did a regular alarm in a 2000 civic in about 2 hours. The remote start would of took me only about another 15 minutes, just another 3 wires. If your car has keyless entry to start with, the alarm will be an easy install. Just have to find the correct wires to tap into and programming the alarm/remote is real easy with most alarms.
