H22a1 Motor into a Crx what's needed?
I'm Shy :(
Originally posted by jlicrx
you can get everything you need - mount kit, shift linkage, axles, cable actuator, etc. from Place Racing - going to cost you about $1200
get it done at a professional shop that specializes in putting in honda engines, DO NOT TRY TO DO IT URSELF, u'll regret it and u'll run into so many problems, where i live in tucson arizona i could have it done for 7000 dollars turn key price for the engine and complete install. not worth it in my opinion but maybe u can find something cheaper out in cali, good luck
I'm Shy :(
I'm Shy :(
Ok I really didn't want to make two threads about the same section so I was wondering how hard and is it a lot less difficult for me to just go and throw in the h22a motor into a 93 Civic Coupe which I found for 1,200 bucks that my friend is offering. What do you think? Also what 1/4 mile times do you think I could do if it was stock?
Let me know thanks you guys for all of your help.
Rotorphile.
I'm Shy :(
Originally posted by Kai
Yes, much easier. Swap parts for that are readily availible and is pretty much bolt-in, except for the cable shift assembly.
Rotorphile.
Is there a lot of welding involved with a 93 civic if I swapped the motor into it?
I'm Shy :(
No, there should be none unless the shifter is welded. It will probably only need to be bolted in.
Now for another question does anyone know a cheap place in bay area california that will bore out my cylinders? I want it done professionaly but I don't want spend a grip doing it. I'm going to eventually buy high compression je pistons and rods.
crvtec beast
swap into a 92-95 hatch
not worth it to ruin handling qualities of a crx
crx needs a small motor
do a b16 swap or somethin
even if you have the h22a your gonna need some serious suspension work to have a normal handling car.
understeering aint fun
