independent throttle bodies.
Z20 H8R
would it be worth it or even thesible to have a multi throttle body system on a daily driver? the whole setup is as follows ~2000 for the manifold/tb's and then another 1000 or so for the fuel management and computer setup for it. now would it be economical i should say to use it on the daily ride? does anyone know any info on these systems? any hp gain info? i have found probably 2 or 3 setups that are availible. but little info on them. one of the setups has a resonator box that you can clip on to the tb/manifold and use it for a intake collector and you can run a tube off it to use a filter. well any opinion would be helpful. also if anyone knows where to find a good setu pfor cheaper than i mentioned please let me know! thanks alot!
Some guy in the basement posted his itb conversion on a d16z6 I believe, it's still in progress. I'm still waiting for it to be done. I think it's pretty neat but I'm betting that the gains won't be that great. I'm sure the conversion is expensive.
u do get added power, along the entire power band but its an expensive way to go for such little power but u can get newhere from 5-20 hp depending on check out this
http://www.todaracing.com/products/h...ction_kit.html
Z20 H8R
yeah thats what im looking at...its so sweeeeet. :boink: i think its the same setup that skunk2 used on their NA 11sec car.
i saw that mtv show..its where i got the idea...kinda. he uses it on his ITR RHD daily driver too...but is that not some overkill? heh.
Originally posted by TeHJuSTiN
There was a guy on MTV's True Life: Im a Street Racer, who was alledgely putting down 220whp with an ITB setup.
